PC Chassis Front panel
This may sound odd, how do you repair the plastic "things" that hold the front panel of a pc to the chassis?
Any suggestions would be appreciated.
5 answers Last reply
More about chassis front panel
  1. What case in particular are we talking about?
  2. Eureka--by Thermaltake
  3. I guess you were trying to quiet the front intake fan? The video review didn't show the bezel being removed though.
    Generally speaking, if you broke plastic tabs there's no permanent repair. You can try new ways of affixing it. Depending on how many tabs are broken. Velcro tape might be enough.
  4. --actually the front power switch died and I forgot momentarily that both side panels had to be off before the front panel could be removed. The top "tab" on both sides is sheared off, but the remaining ones work. I did not think about velcro, that just might work. Thank you!!
Power Supplies Front Panel Components
