I'm currently considering of upgrading some part(s) of my PC.
Case : CM Storm Scout
PSU : Silverstone Strider 600W
CPU : AMD Athlon X2 7850 BE 2.8Ghz
HDD : Western Digital Caviar Green 1TB 64MB Cache
Motherboard : Asus M4A78 Pro
Memory : Mushkin Extreme performance 2x2 2GB
Video Card : Asus EAH4870 DK 1GB DDR5
OS Windows WIndows 7 64bit
Speakers : Logitech G51 Surround Sound
Monitors : (Main) Acer AL1916 19" Monitor / Samsung T220 22" HDTV Monitor
For future reference, don't tell me to get Intel CPU please.
I'm considering of getting the AMD Phenom II X4 955/965 but I would like to know if there is actually a major difference between them, and if not, what would you suggest?
I also need to get a cooling fan for the CPU, any suggestions? Before you suggest anything, I want a cooler fan that's tools free and is able to install with your own hands. Sadly, my options are limited since I'm not purchasing it from Newegg. I would be using CanadaComputers only (http://www.canadacomputers.com/index.php?cPath=8_129) Please don't go beyond $80
I'm still not sure what motherboard to go with, or is it not necessary? I'm certain I would still able to use it since the mobo is compatible with AM3, unless I'm wrongly mistaken.
I actually do think the only thing at the moment I need to upgrade is the CPU, BF:BC2 is a CPU Monster Eater making my load at 100% at times.
I would like to hear your opinions what I should upgrade, but currently my main upgrade has to be the CPU. I'm not looking for something extreme, just something like casual gaming wise.
& For the record, I'm also upgrading my 19" Acer monitor to another 22" or 24" in the near future unless the CPU is the only thing I'm upgrading, I would also pick up another monitor when I buy the CPU.
