$500 general purpose PC need advice on parts
Hi, This is my first build and I'm having difficulty picking out parts and need some recommendations
APPROXIMATE PURCHASE DATE: within the month
BUDGET RANGE: $500 can stretch the budget to $650
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, schoolwork
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
COUNTRY OF ORIGIN: United States
PARTS PREFERENCES: no preference
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: 1024x768, possibly get a better monitor in the future. would rather leave monitor expenses out of this build
ADDITIONAL COMMENTS: First build ever, not too tech savvy on hardware, still learning by reading the forums. I've looked at the gpu's and cpu's that I would like to use but not sure if there's anything better for around the same price. What I want or expect from this build is something that can play MW2 on medium settings nothing too fancy, starcraft2,company of heroes and prospectively guildwars2. Going to be using this for gaming as well as schoolwork. most likely want to upgrade gpu or cpu in the future. would also like to minimize the cost. Thanks.
PNY VCGGT2405G5XEB GeForce GT 240 512MB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133306&Tpk=PNYVCGGT2405G5XEB
Intel Core i3-530 Clarkdale 2.93GHz 4MB L3 Cache LGA 1156 73W Dual-Core Desktop Processor BX80616I3530
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115222&cm_re=core_i3_530_2.93ghz-_-19-115-222-_-Product
4 answers Last reply
More about general purpose advice parts
  1. Well my question now is, could i stick with my choices for the cpu and gpu?I would really like to have 3 or 4 cores but i can opt for 2 cores. being that my purchase date is still far off, its possible to extend my budget further, just means i gotta work more bleh :??:
  2. Here is a better CPU/GPU combo:
    Same video card - Sapphire Radeon 5770
    Triple core CPU - AMD Athlon II X3 445
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.442727
  3. You'll get a much easier and larger overclock out of the X2 555, plus the chance to unlock more cores.... the Athlon II is a good deal if you aren't going to OC though, and might unlock to PII X4 status.
New Build Systems Product
