alright this is my build
CPU/GPU: X4 955 and HD 5870 $530
Mobo/PSU: Gigabyte GA-790XTA-UD4 and Corsair 750HX Modular $215 after rebates
RAM: G.Skill Eco 2x2 GB 1600 mhz CAS Latency 7 $105
HDD: Samsung Spinpoint F3 1 TB $75
Case/Optical: Coolermaster 690 and cheap SATA DVD burner $83
Monitor: Asus 23" 1080p $170 after rebate
OS: Windows 7 Home 64-bit OEM $100
now when i try to install win 7 the drive showsup but when i go to format it it says it is in read only or it is installed incorrectly i tried moving it around the satas hdd is in master slot and not sure whati can do is it a problem with mobo or hdd can anyone help plss
