I am using a intel q8400 with the intel stock fan. in idle
core 0 = 56 core 1= 49 core 2= 53 core 3 =56
in load
core 0 =61-66 core 1=54 core 2- 59 core 3=62-67
in prime 95 the temp goes up to 72 on 1 core while the other core are <=72
is the load temp good? it is when i am playing just cause 2.
or should i buy a third party hsf
i cannot afford higher end hsf. the one i can go with is cooler master hyper tx3. will i see less temp when i install it
also will tx3 fit in codegenworld qori 3335 cabinet? how about performance of tx3?
in load
