Hi
i need some info on wheather what I see is just and error or if my RAM are underperforming.
below mentioned are my pc specs
Operating System : MS Windows 7 Ultimate 32-bit
CPU : Intel Core 2 Duo E7500 @ 2.93GHz 40 °C
Wolfdale 45nm Technology
RAM : 4.0GB Dual-Channel DDR2 @ 333MHz (5-5-5-15)
Motherboard : Gigabyte Technology Co., Ltd. G41M-Combo (Socket 775)
Graphics : BenQ E2200HD (1920x1080@60Hz)
NVIDIA GeForce GTS 450
Hard Drives : 488GB SAMSUNG SAMSUNG HD502HI ATA Device (SATA) 33 °C
Optical Drives : UBEXMX O5AVCPM3C1EB SCSI CdRom Device
HL-DT-ST DVDRAM GH22NS40 ATA Device
Audio : SRS Audio Sandbox (WDM)
if you have notices my RAM shows frequwncy of 333mhz
I have 2 sticks of 2gb each both running at 800mhz at dual channel, however the effective frequency shows as 333mhz. i dont see any significant drop in performance but just concerned about the specs displayed in cpuz and speccy, should i ignore this or is there some change needed..
Thanks..
Thanks..
