My computer
CPU-AMD 720 X3 BE (not unlocked or overclocked, both of which seem to freeze the MB)
MB-Biostar TA790 GX 128M
Memory-4 GB G. Skill RAM
GPU-HIS 6850
PSU-Corsair 650w
Case-Lian-Li PC7B
HD-1 WD640 GB partitioned as C:\ E:\ J:\
HD-2 Hitachi 1 TB D:\
HD-3 La Cie 1 TB external USB 3.0
HD-4 new today, but still in package - SSD 256G|SAMSUNG MZ-7PC256B/WW R
DVD-Generic DVD player
Windows 7 OEM
I have had sporadic episodes where the OS freezes while loading at the black screen with the Windows logo and won’t go any farther. I have to turn the power off and then on which usually allows a normal boot but sometimes proceeds to repair mode, where nothing is ever repaired. Occasionally I have to go to a restore point. So I bought an SSD which arrived today without really knowing if it's compatible with what I already have.
Also sometimes my Hitachi D:\ drive will not show up in My Computer, again for no apparent reason. It seems that when that drive doesn't appear I'm likely to have the other problems with drive freezing or getting a BSOD.
1) Does anyone have any suggestions for diagnosing the two current sets of disk problems?
2) The La Cie comes disk image SW. Can I make an image of C:\ alone and install it on a my SSD and have the OS work? Is there a guide for such an upgrade? Or can I do a fresh install of my Windows 7 OEM to a SSD or is that technically prohibited?
Help appreciated.
GPU-HIS 6850
PSU-Corsair 650w
Case-Lian-Li PC7B
Windows 7 OEM
Help appreciated.
