CS5 system build
APPROXIMATE PURCHASE DATE: (e.g.: this week (the closer the better))
BUDGET RANGE: 1500 - 3000
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: CS5 Premiere/After Effects, Audio Editing Software (Fruity Loops), Word, internet
PARTS NOT REQUIRED: Case, Power Supply, Keyboard, Mouse
PREFERRED WEBSITE(S) FOR PARTS: No prefrence
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: Intel CPU's, ASUS Mother boards. Nividia. No other preferences.
OVERCLOCKING: Only if needed for after effects.
SLI OR CROSSFIRE: Don't know what this is.
MONITOR RESOLUTION: No Prefrence
ADDITIONAL COMMENTS: Burning questions are how much ram do I really need, and which Nidia graphics card should I get for After Effects to work seamlessly.
1 answer Last reply
More about system build
  1. I'm not a pro with this sort of build, but this is a good foundation:
    Intel i7 930
    Gigabyte X58A-UD3R (This is the general recommended X58 mobo. I can look for an Asus equivalent if you wish)
    6GB-12GB RAM:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145286&cm_re=corsair_DDR3_6GB-_-20-145-286-_-Product
    (Nvidia) 1GB GTS 250
    Do you need a monitor?
New Build Photoshop Systems Product
