Problem with DVI to VGA convertor
frnd plz help me
Processor Pentium(R) Dual-Core CPU E5800 @ 3.20GHz 6.6
Memory 4.00 GB
Graphics NVIDIA GeForce GT 440
monitor acer v193hq
max resolution 1366x786
this is my pc configuration
in my monitor i have only VGA port but my graphic card has only DVI port
i am using DVI to VGA converter hub
but is shows anolog display with max resolution 1600x1200
when m trying to enable stereoscopic 3D THEN my monitor show a message WITH BLACK SCREEN "INPUT NOT SUPPORTED"..
plz help me how to conevert my display ANALOG to DIGITAL...................
3 answers Last reply
More about problem convertor
  1. If you go to the Nvidia home page and look at the stereoscopic 3d page you will see under the specifications tab that it is only supported by a dvi connection. That means that the dvi to vga connector changes your input to vga and therefore not supported.
  2. If you want to convert your display from analog to digital you need to buy a new monitor that has DVI inputs.
  3. thnx inzone but this is not a solution of my problem
    in present i cant buy a new monitor
    because its out of my budget.....
    m searching for a software or driver which can solve my problem.......
    and stereoscopic 3d also works on vga connection
    i was using stereoscopic 3d on my old card GT8400
Configuration Windows 7
