APPROXIMATE PURCHASE DATE: This week.
BUDGET RANGE: $1000/ After Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Internet/work, movies, video/MP3, amateur CFD/CAD, experimenting, programming
PARTS NOT REQUIRED: N/A
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: None
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: at least 1080
ADDITIONAL COMMENTS: This is my first build. I would like to know if I've picked quality components that are compatible before I buy them. I've spent the past week or so researching. I know I can save money going with AMD. I think I would rather have an intel system though. Also, I was previously considering a 5770. I like the idea have having eyefinity, but I wouldn't have multiple monitors right away. I don't game, so I'm thinking having CUDA is more in line with what I'd like to use the computer for. 6GB might be a bit much too. I would just like a fast computer that I won't need to mess with for several years.
CPU/Mobo: I7 930/Gigabyte GA-X58A-UD3R
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.437357
GPU: Gigabyte GTX-460 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125333
Memory: G.Skill Ripjaws 6GB PC3 12800 (3x2GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231304
PSU/HDD: Corsair 650TX/Samsung F3 1TB
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.431396
Case/DVD: CoolerMaster RC-690/Samsung 24x
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.435592
This totals to 1,086.93. Then I need a monitor and Windows 7. Thanks for the help.
OVERCLOCKING: Maybe
