Temperature issue of Zotac 9800GT
hey guys I have a real problem here...
I have Zotac 9800GT 1 GB DDR3.
I mount it on a PCI slot.. then install drivers and install software call filestorm. And what I see " temp. is 53 C"
when I play games for 20 minutes then it goes to the 72.
Now what can I do guys .. please help me ..
How can I fix this temp. isuue
9 answers Last reply
More about temperature issue zotac 9800gt
  1. Those temps are perfectly normal, and within the spec for the card - don't worry.
    My worry threshold would be if your card goes above 90c when gaming.
    If you want to bring the temps down you can use rivatuner or nvidia's ntune software to increase the fan speed of the card manually.
  2. what if temp. goes 90C.. Then what I can do?
    And in the software i.e rivatuner or ntune how much should I increase fan speed.
    So that my my GPU stays cool and it doesn't damage any way...
  3. The max temp for a nvidia 9800 GPU is 105C! 72C is fine under load.
  4. Don't be afraid, your temps are cool, man... :D
  5. ok one more thing.. My friend suggest me that I have to get the cooling pad for my GPU.
    Is that necessary? I mean in the future.
  6. cooling pad? Do you mean an aftermarket gpu cooler?
    You are fine as is. What is recommended to do is clean out the heat sink and fan on the card ones in a while dust and lint affects cooling a lot. I clean the internals of my computers at least every three months.
  8. Is power supply affects?
    I have 450W ATX power supply.
  9. Seriously, those temps are fine. GPU's get seriously hot, and can even be a tiny bit toasty on idle, they are designed to cope under that sort of heat.
    That applies doubly so for a card with an age like yours.
    Like rolli59 says, keep your computer free of dust, get airflow over the card, and it will be happy.
Graphics Cards Zotac Temperature Graphics
