Jumper settings pls help
hi
i recently purchased a new samsung 2370ms and connected it with dsub cable and every thing was fine then i bought a new dvi-d cable [wanted to see the diff] but wheni plug it, some times it warks fine but generally i get a jumper error and the bios gets open automatically with a msg that pl change jumper settings and then reboot ???
i never touched the m/b so dont know what to do ??
any help will be received with thanks.
m/b: intel dg35ec
proc: intel q6600 2.4ghz
More about : jumper settings pls
Look in your manual for resetting the CMOS jumper. It's a little pin that you remove and put onto these other two pins to short the battery connection to the BIOS. This resets it and then you put the pin back where it was. You may also just want to load the default BIOS settings first and see if that works.
i tried loading the default value but i still get an error, will try as you said and will revert
Ask the community
