Hello,
I lost my wireless connection after updating to IE 7. I read you can disable homegroup, how do you do that?
Changing the version of IE sholdn't impact on your connection - check in the Tools menu then Internet Options>Connection tab>LAN button and make sure there's a tick in the "Automatically detect settings" box. Homegroup is a Windows 7 aid to networking and won't change the ability to connect to the Net.[/#000ff]
