my secondary computer (aka ex-primary computer now used as an overweight stationary mp3 player) spontaneously turned off a few weeks ago and hasn't turned back on. At first, the power light would go on when I tried to turn it on and then stay on until I cut power, but now that doesn't happen any more. I thought it was probably a PSU problem and figured I'd get around to it eventually but wasn't worried because I have a better computer that I use for everything... until now!
Exact same thing happened to my primary/main/good computer... well, same initial symptom anyway... It turned off in the middle of me typing an email and won't turn back on. I immediately felt the CPU heatsync (I know how hot it feels to touch when it's well over 50 degrees Celsius and can tell it was nowhere near that as weird as that may sound) and I'm damn sure it didn't overheat (I never see it go over 35 anyway, I only know what 50+++ feels like because my old computer averaged 50-65 under load). Hours and hours of video games have never pushed my GPU over 47 degrees celsius and I wasn't gaming when it happened so I doubt the video card got too hot. The power supply feels pretty warm but it always does, I don't know if that's normal or not but it's normal for my comp. I don't really know what to do, all I've tried is unplugging it, plugging it back in, hitting the power button... and giving it time. The only sign of life is my mouse lighting up when I press power and the green power light on the front turning on, needless to say I really hope it's nothing serious and I want to get it back up and running ASAP.
any ideas?
system specs:
500w psu
core 2 celeron e1200 (1.6ghz)
2gb ddr2
radeon hd 4650 (512mb)
OS: windows xp pro sp3
let me know if you need want to know anything else
any ideas?
system specs:
500w psu
2gb ddr2
