Help setting my Memory frequency to 1600 MHz
I'm going to try and make this as specific as I know how. I'm using an EVGA X58 FTW 3 Motherboard with 18 GBs of RAM, I'm using the Windows 7 Home Premium 64 bit OS so I'm only able to use 16 GBs of it. My Ram consists of 3x 4GB Corsair Vengeance memory sticks. That is this Ram right here. http://www.bing.com/images/search?q=4gb+corsair+vengeance&view=detail&id=457AAFA170026CF07AEA239467C2DE05C3418F88&first=0&FORM=IDFRIR
My other kind of Ram is this http://www.bing.com/images/search?q=high+performance+ddr3+memory+triple+channel+ocz&view=detail&id=1888E76CCD85F89D4BC4AA5F7B668C7C66CB9D0E&first=31&FORM=IDFRIR which I believe to be my other set. I also have 3 of these.
I know mixing Ram can cause problems, both sets of RAM are 1600 MHz. I need their timings set and I need them properly configured in BIOS to work with eachother. How might I set these to get their full performance without overclocking them?
In BIOS, I would like my memory frequency set to 1600. How might I configure my BIOS to achieve greater performance? Thanks in advance for your help, and tell me if I forgot to mention something.
1 answer Last reply
More about help setting memory frequency 1600
  1. Does anyone know or have any ideas?
Memory RAM
