Hello,
When I went to repair my other HDD (Cause:Bad Sector), i plugged it without turning PC off and the result there was it burned the power cable (I use converter from 4pin cable to sata power). And then i tried another HDD and it was just the same as the previous try.
When i unplugged it it gets hot in the circuit
And the cable was fried. (it fires up) (I spontaneously unplugged it)
I keep having a same result when trying in another PC
Can i still use it?
First try HDD: WD Green 500Gb
Sec Try HDD: WD Blue 160Gb
Sorry (My ENGLISH is bad)
Can i still use it?
