Hi all, I bought the following memory recently http://www.microdirect.co.uk/Home/Product/50220 however there's a small problem. It's not operating at the speed it advertises, and when I try to set it to that manually in the bios, it freaks out and won't boot. Current speed is around 700Mhz which AFAIK should be 800Mhz. screenshot here: http://www.imgjoe.com/x/memspeeds.jpg
Both modules are in identical slots on the motherboard (two blue ones, Asrock M3A UCC mobo) and have the timing set manually to 9-9-9-24.
My CPU (AMD Phenom II X4 965) is OC'd to 3.6Ghz but the same happens even at stock speeds. I only bought this memory yesterday too so I could still take it back to the shop if you think it might be worth doing.
Can anyone shed any light on this? Thanks in advance
