I have my system build but plan on overclocking it so I will need more than stock cooling not really looking for liquid cooling as I would have to rebuild my system and spend more for cooling.
Case - Hades NZXT (need another top fan)
MOBO - Crosshair IV
CPU - Deneb BE 125W @ 3.4Ghz (need a great heatsink)
PSU - 750W Silencer (should handle OCin)
GPU - HD 4850 ATM, planing on XFX HD 5970 BE
RAM- G. Skill 4Gb @ 1600
Thanks in advance for all advice.
PS: I was thinking of OCin my CPU to 4GHz but when I had it at 3.8GHz my index score for graphics went down (not that index is important but helps show bottlenecks)
EDIT: If I don't reply I'm more than likely camping and will be back in a day or two.
MOBO - Crosshair IV
