Problem: Reliably access desktop computer while traveling.
Remote connection is established using GoToMyPC. This means the computer must be on during the whole trip. If the computer shuts down for any reason or ‘hangs’, someone must be called to come to the office and reboot it. (This is a one person office, i.e. there is no one handy to walk over and manually do this.)
I intend to place the computer, cable modem and router all on a UPS with the computer set to power on after power fail.
However, it would be very desirable to be able to leave it shut down except when actually being accessed. And it would be desirable to be able to reboot the system if it ‘hangs’.
Goal: To be remotely, via the Web, be able to:
1) power up computer after normal shutdown.
2) reboot the computer if the system hangs/locks up.
The system has an ASUS P6X58D-E motherboard and is running Windows 7 Pro.
Thanks for any advice you can offer.
