How can i determine if graphic card is the problem
mottov2
4
a friend of mine asked me for his help.
as soon as he logs into windows, a few seconds to a few minutes later, the thing freezes. Then i start seeing weird sort of like pixelated vertical lines all the way across the screen. I suspect its the problem with his video card, but how can i determine if the gpu is the problem, if it is, how can i tell if its bad driver or just bad hardware?
his computer is a hp pavillion media center.
windows vista 32b
AMD chip..i forget which one it is.
Nvidia Geforce 8900 or 8900 GT.
leorick
81
Bad drivers, specially on nvidia hardware will most definitely result in a quick BSOD and the PC will restart automatically. Those vertical lines might be an indication of a failing graphics chip. Only way to test is if you can borrow another card or if you have an on-board graphics just like what ct615 said :p
