ok so i found an old computer in a garage sell for my daughter its a dell optiplex 270 when booted it up i get some small lines evrywhere in my screen blue yellow purpule red anyone know if the video card could be fried or is there a way to fix this
Open it up, remove the card, clean the dust out, then reseat the card, hopefully its just making a bad connection and causing the artifacts because of that. If not you can replace the card but i believe they took AGP cards so you will need to find an AGP card which arent very common anymore.
