CM Storm Sniper front fan cleaning
Last response: in Components
We removed it and applied a thin layer of 3-In-One oil,
using a cotton swab.
Hold the cotton swab in a vertical position,
and let 1 of 2 drops of oil soak into the cotton.
That will give you much more control over the oil.
Now, the front bezel snaps in and out with greater ease.
MRFS
Related ressources
MRFS
Oops, I read your repy after replying to Davcon. You do this before removing the bezel for the first time?
> you remove the front panel, then oil it to aid future removals
Correct: thus, the first time it will probably be somewhat more
difficult to remove: so, flip it over so you can get a good look
at what you should be pulling on.
Also, the video by Rodney Reynolds is excellent:
Rodney really does a wonderful job on all of his videos.
MRFS
Ask the community
