Solved
Power supply for Core i7 build
Last response: in Components
I'm building a new machine around a Core i7 950 CPU, a GA-X58A-UD3R motherboard, and an ATI Radeon HD 3450 GPU or similar graphics board. I’ll start up with 3 sticks of 2 GB RAM and add more RAM later. For HD I'll probably go with the Western Digital Caviar Black 1TB. I'll also install a HP RW/DVD disc drive. All those components weigh in with a power requirement of ~450 watts. However, I'm going to buy ahead for expansion in a year or so and install a PSU in the range of 600-750 watts. I want an electrical source for this new build to include modular wiring, multiple rails, and the full complement of overage/underage protections offered inside top line power supplies.
I'd like to get as close as possible to these criteria in a price range under $100. However, I'm willing to go higher if the value is there.
Does anyone have recommendations or other comments about the best value in a power supply unit that I can find on the web?
Thanks for any and all feedback. :hello:
Corsair and Seasonic are two brands that have a reputation for high quality power supplies that consistently earn high marks in technical reviews. They are reliable, stable, and come with a 5 year warranty. Some of the newer models come with a 7 year warranty (in the USA).
Related ressources
2178019,7,345420 said:
An HD 3450 on a X58 rig.! What's up.?[/quotem
I went with the Gigabyte GeForce GTX 460. The HD 3450 was a placeholder, and, as you point out, a misfit.
This is what I finally ordered in addition to the GTX:
Chassis: Antec P183
Memory: Corsair Dominator GT 6 GB PC3-16000 2000Mhz
HD: WD VelociRaptor 300 GB
Motherboard: GA-X58A-UD5
Power Supply: Antec CP850
CPU: Core i7 950
Storage: WD Caviar Green 2 TB
What do you think? I should be able to begin assembly this week.
omg.... first... why velocirraptor!!! u should get a ssd not velocirraptor...
second... caviar green :|... u should get samsung spinpoint f3
and third 850w its a lot for that... 650w/750w would be sufficient to power gtx460 in sli...
Best solution
SSDs are WAAAY to small that is why.
Thank you for that feedback. I took it to heart and switched the hard drive build to a RunCore Pro IV 128GB for the boot drive and a Samsung SpinPoint 1TB for primary storage. The velociraptor has been delivered, and I'm assuming I will send it back -- although I suppose I could add it as a secondary storage, which might be a waste of money, except perhaps to use it for all essential on-site backups.
Here's the system I'm ending up with
Graphics Card: GV-N460OC-1GB
Case: Antec P183
Hard Drive: RunCore Pro IV 128GB 2.5" SATA Solid State Drive
Processor: Intel Core i7 950
Motherboard: Gigabyte-X58A-UD5
Storage: Samsung SpinPoint F3EG HD103SJ 1TB
Fans: Thermal SpinQ VT
???=WD VelociRaptor 300 GB
Ask the community
