Why wlan wireless is slow
Last response: in Wireless Networking
Anonymous
Wireless Authority
Some more detail from you would help. Meanwhile be aware that wireless is always about half the speed of wired because it is duplex. This issue is made worse by poor reception or interference.
Usual remedies:
1) raise the router above furniture level
2) Experiment with channels (some will work better or worse depending on your environment)
3) If you can detect strong neighbouring wifi, use a channel 5 stops away from strongest.
4) Relocate cordless phone base or video sender etc.
5) Be prepared to move the computer (or at least turn it so your body is not between the router signal and the wireless adapter's antenna).
Ask the community
