Hello,
I'm looking to build my first PC and definitely going to be using the i5-2500. I do not plan to OC at all so that is fine. My question is I know I'm suppose to get a H61 or H67 MB but I see better deals on a P67 MB, so if I get that, will there be any kind of problems or can a non K CPU go with the P67?
Also most H67 MB can only use 1333mhz ram but I kinda want to get 1600mhz ram as I want to future proof as much as possible. Will I really notice the speed difference? Or will the computer blow up if I use 1600 ram on a MB that only supports 1333?
First time builder as I stated and not much of a gamer but just want the best as possible without breaking the bank. So any help would be appreciated. Thank you.
