New built i5-750/gtx470/fsp 700w ???please help
Hello,
I'm from kurdistan
Planning to buy a new pc for gaming
And already chosen this parts:-
Cpu:-I5-750
Ram:-kingmax 4gb(2x2) ddr3 1600mhz
Hdd:-1tb wd
Odd:-liteon 24x
Monitor:-lg 2262tq 22'' full hd
Gpu:-gtx 470(zotac or evga due to availibility)
Keyboard & muse & speaker
Now I dont know if following parts compatible or not:-
M.b:-asus p7p55d pro or msi gd80 or msi gd65
Psu:-FSP 700w
Case:-hexar turbo
Ups:-tripp lite 750va
My questions:-
1.Is tripp lite 550va good for my build or may i choose the 750va one?
2.what r main differences between motherboards?
3.My PROBLEM is power supply , will fsp 700w be OK with my sysem and largely with gtx 470?
4.case :the best case that can be found here is a chineese case named (hexar turbo) which has 4 small fans on both sides,may i buy it ?and will this simple cases be ok with the system above ?
I need help ,please answer my questions specially third which is about psu.
Thanks
37 answers Last reply
More about built gtx470 700w please help
  1. Quote:
    The PSU has enough power for your system running only one GTX 470 but why would you go with the GTX 470 when the HD 5870 is much better in performances and has the same price range.
  2. Thanks
    But are you sure?
    Is it compatible just by being a 700watt or when you say that you mean everything like amount of amps on each 12v rail and...?
  3. You need 35 Amps in total available on the +12 volts rails to feed the GTX 470.
    Here's a FSP Epsilon 700w review for you:http://www.xsreviews.co.uk/reviews/power-supply-units/fsp-epsilon-700w/1 , and i would raher go with another power supply manufacturer(Corsair, Antec, SilverStone, Seasonic, and OCZ) if they are available in Kurdistan
  4. If you are looking for a Xfire in the near future i would recommend a 1000W PSU that needs to have (in total accumulated) at least 55 to 60 Amps available on the +12 volt rails, but as i said i would rather go with the HD 5870...
  5. Ok i understand
    So i'll buy fsp 700w and i wish it works correctly.
    And about your question why gtx470 and not 5870?
    Gtx 470 =450-500$
    Hd5870=600$
    Prices are too high here ,the whole above system costs me about 1800$ without operating system because just the cracked version can be found here.
  6. Do you have any other PSU brand to chose from?
  7. Yes just another one:-
    X-factor 600w
    But i googled it and found nothing and i think the fsp 700 is much better than it.
    Why?
    Why not the fsp 700w?(brand?lifetime?...)
  8. Well yes it's the brand mainly but if you do not have where to chose from you can go with the FSP 700
    Quote:
    I'll be honest, the Epsilon does seem a little overpriced. It's 3.3v and 5v rails are nice and stable but the 12v strays a bit when putting it under load. They are also over 0.4 of a volt outside of what they are aiming to be; not that tight. However, the Epsilon does have a quiet cooling solution and its rather nice to look at in its fetching blue. For a 700w PSU there are probably better ones out there, but the Epsilon from FSP is hardly a poor choice
    This is from the review page , and you should also read this if you want to know why i don't second the FSP.
  9. Thanks
    what i have to do?
    May i go with it?
    What kind of problems or... will i have with it?
    Can you help about the case i said in first post?
  10. Search the internet for a better shop in your country.If you can't find anything i would go with the FSP 700W since the other X-factor 600w is an invisible PSU on the market.Atleast we found a review about the FSP and it's not such a bad one.Problems: a PSU can cause a system to display a wide range of symptoms which also resemble other issues but this is by chance i would say, I personaly am running a Noname PSU on my 2nd PC for 4+ years now and i never had a problem with it and goes 8-12 hours a day.You can keep it clean for 1 thing that will ensure a longer lifetime( http://www.ehow.com/how_5045654_clean-pc-power-supply.html ).
    The case is also invisible i can't find anything about it but if it has a good airflow, some cable management support and offers some space i would go with it.
  11. Thank you
    No other choices so i will buy them(psu & case).
    There is no internet shops in my country and the shop that i am going to buy my pc at is not an internet one.
    Thank you again
    I'm waiting for answers of my other 2 questions about ups and m.b !?!?
    Anyone can help?
  12. As far as motherboards go, I'd go with Asus. MSI boards have a tenancy to over-volt when overclocking (and you really SHOULD be overclocking that i5).
    Moreover, ASUS is a better brand (marginally).
  13. Thank you for your answer.
    But why you said :- you SHOULD overclock it ?!?!
  14. Oh and as Tom said, GT470 = not that good. The entire GTX 4xx series consumes way more power and wallet than the Ati 5xxx series. (Also note that though the GTX470 performs between the HD 5850 and HD 5870...it's a lot closer to the 5850)
    And $600 for a HD5870?! That's a major ripoff! The GTX 470 itself should also be around $350. not+$450
    Check out this store: www.ewiz.com
    GTX 470 $350
    HD 5870: $450
    HD 5850: $300
    They also do international shipping (can only pay via wire transfer though)
    You should NOT be paying $1800 for your system. With that money, you can get yourself a decent i7 build on ewiz. I got myself a similar i5 build for less than $1000 (shipping included). I also don't live in the US/UK so finding a local store with a quality selection is nigh impossible. That's why you should import...especially as an enthusiast.
    Moreover, you can get yourself a much better case+PSU combo on ewiz. I would strongly warn you against buying a no-name brand for a PSU...especially if you're gonna be gaming. My previous system had a random PSU manufacturer (Procase) and that PSU (600W!!) was the first component to fizzle out.
  15. Quote:
    Because the i5 can easily be boosted to 3GHz with little hassle and the extra performance is worth it.
    I can boost my i5 to 4.2GHz and that gives me the performance of an i7 970!!! (almost :p )
  16. Thanks lotus
    I checked ewiz.com and yes it is international but i live in the north of iraq(kurdistan) which is not included in location selection.
    And i want to overclock it if there will be auto overclock with stock fan.
    I DON'T KNOW WHAT TO DO !!!
  17. Ack! Yeah it will be hard to find companies that ship to iraq...you could use a forwarding agent such as www.myus.com though but that might incur a lot more hassle and costs for you. I'm stumped too there...
    Don't worry about the stock cooler...you can still OC with that and i5s come with a turbo-boost function that allows you to OC with the click of a button. Just watch the temps and voltages though...
  18. Thanks again but it costs me more than here and i decided to go with the parts that availaible here so i went to market and found this 3 parts:-
    1.psu gigabyte 800w odin pro
    2.psu huntkey 700w
    3.a gigabyte big case that i dont know what is the model but it was a black , big and simple one price:120$
    Please Help with these psu's and are they better than fsp 700?
    And the case is it better than simple and small ones in the market?if you think you know its model plz add a link to it in ur answer.
    Thank you
  19. Thanks again but it costs me more than here and i decided to go with the parts that availaible here so i went to market and found this 3 parts:-
    2.psu huntkey 700w
    Thank you
  20. Quote:
    2.psu huntkey 700w
    Thank you
  21. Sorry about above post ,i am writing it with a wap browser on my mobile and you know sometimes it hangs and...
  22. Although it is overkill for your system i still would recommend the 800W odin pro from Gigabyte as it has some good reviews.The other psu huntkey 700w i could find some unpleasurable reviews here.
    As for the case see if you can recognise it here.
  23. Thanks but Case link goes to nothig can you write the model?
  24. And do you think the 800w odin pro will be ok with gtx470 and an oc'd i5-750 and rest of the system?
  25. Finally i ordered asus p7p55d pro 220$.
    P7p55d evo was available too but 260$ , so is my choice(pro) is better choice over (evo) according to price/performance and specification?
    I mean what is main differences between them?
    Tnx
  26. 1st:The are insignificant differences between the 2:
    P7P55D PRO:(2) 2.0 16x (8x+8x in Crossfire/SLI) & (1) 2.0 4X12+2 phase & few less features than the EVO
    P7P55D EVO:Same as PRO but has a few more features including a clear cmos on the rear i/o panel+The Evo apparently has TurboV Autotune.
    You made the right choice since the +40$ can't be justified on the EVO.
    2nd:As long as you don't have another better brand to chose from the odin can keep your system running.
    3rd: Here is the cases link : http://www.gigabyte.com/products/list.aspx?s=51&p=146&v=15&ck=9
  27. Oh thanks
    I think i found the case model and it is iSOLO 3134 and it costs me here around 100-120$
    So is it a good one?
    Will it be ok with gtx470(heard it is a card)?
    And is it good for tempreature?
  28. Yea m8 compared to my Antec 300 it's way bigger, it comes in form factor ATX so you can fit the mobo, tool-less and cable managed, liquid cooling upgrade ready, washable dust filter and you don't have to worry that your PSU won't fit since they are from the same manufacturer.As for the GTX 470 i think it will fit in since my HD 5850 fitted in the Antec 300 and it's half centimeter smaller : http://forums.bit-tech.net/showthread.php?t=185149
    It's to 12cm vents front and rear so the temperatures should be ok but i am not much of a case expert so don't take my advice in cases airflow.
  29. Thaaaaaaaaaaaank you
    And do you recommend it?
    I dont know , buy or not?
  30. Can you help with ups
    Which one is enough for my system with monitor(lg w2261vp or lg w2262tq) :-
    1.Tripp lite 750va
    2.Tripp lite 550va
  31. Can't help you there don't know much about UPS systems.
  32. However Thanks
    Anyone else can help plz?
  33. Can anyone help with this too:-
    CANYON GAME WHEEL GW3
    Does it perform good in games like dirt 2,nfs,gtaiv,tdu and ...?
    And will i experience another taste of racing games with it?
    Or it dissapoints me!
    Can you suggest me buy or not(with ur opinion about it)?
    Thanks at all
  34. Hello again
    Unfortunately the gigabyte odin pro 800w psu is sold out and now they have Huntkey 900 .
    Huntkey 900=140$
    I want you to suggest me to buy it or not?will it be ok with my system (i5-750+gtx470+...)?
    And if i change gtx 470 and got gtx460 X2 (sli) ?
    And the case that i said (isolo 3134) isn't in stock anymore and he said they have another gigabyte case (prc 401) , anything about it?
    anyone can help, please ?
    Thank you
  35. lotus do you know if ewiz ship to south africa?
New Build Cases Intel i5 Systems
