The reason I ask is because I just replaced my worn out Lite-On PATA DVD drive with a new Lite-On SATA drive. This is the only thing I changed and as soon as a disc tries to autoplay, or as soon as I try to read files on the disc, the computer restarts. My power supply is older and does not have actual SATA power connectors, so I am using an adapter. Would the SATA DVD drive require just enough more power that it is overloading my power supply with it starts to spin the disc? The Case is a Xion that came with a 450 Watt power supply. I know built in power supplies are not always known for their durability and build quality, but it has lasted me a few years with no problems.
Do you think the power supply is the culprit here? That's what I am leaning toward. If the SATA interface draws more power, approximately how much more does it draw in a DVD drive?
