Yesterday i was fixing a laptop for someone a toshiba satillite a45 and it was overheating ( stating up fans going crazy then turning off on its own) simple fix open it up re apply thermal gel then clean the heat sinks.... after putting it back together i tried to start it up and the fans go on for a few seconds then stop and the power light stays on but nothing on the screen no beeps no hdd movement i tried to plug in a screen but that didn't help i also pulled the processor the ram the hard drive and nothing seemed to work i also went as far as taking it completely out of the case a few times to make sure the mobo wasn't bent nothing what do these symptoms lean towards please help btw if i let it sit for a little while its on the fans start back up but more slowly
