Yes No
Ads
Tom's Hardware > Forum > Laptops & Notebooks > General Discussion > Curiosity about battery chargers
Forum Laptops & Notebooks : General Discussion Curiosity about battery chargers
Archived from groups: comp.sys.laptops (More info?)
What is the output form of a typical laptop charger? Is it full wave or
half wave rectification. Is it filtered or smoothed in any way?
No big deal. Just wondering.
Thank you.
Reply to Anonymous
It's DC.
> Thank you.
Reply to Anonymous
They are all regulated DC voltages, from switching power supplies.
Reply to Anonymous
- 0 +
I wouldn't have used the word "all", but your statement is mostly correct.
Problem is that it does not tell the whole story. And what's missing
can lead people to blow up their laptops.
There's "almost" always a current limit. In some cases that limit is
carefully controlled to limit the battery charge current. The result
is that if you stuff in a voltage with a significantly higher current
limit, you can make smoke. Even a supply with a lower limit may run the
laptop fine, but not suupply enough charge current to initiate charge
termination, thereby smoking the battery. Been there, done that.
Lithium chargers have other protections and MAY be immune to this
problem...maybe.
There's probably a sticker on the unit and a big sign in the manual that
says, "Use only with supplied AC adapter." It's there for a reason.
mike
Return address is VALID.
500MHz Tek DSOscilloscope TDS540 $2200
http://nm7u.tripod.com/homepage/te.html
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Bunch of stuff For Sale and Wanted at the link below.
http://www.geocities.com/SiliconValley/Monitor/4710/
Reply to Mike
"Jack Gillis" <XXXXXXXX@widomaker.com> wrote in message
news:10pking558gted0@corp.supernews.com...
> Thank you.
the charger is a switch mode unit. The output is technically derived from a
half wave rectifier, but the way the oscillator driving the rectifier works
coupled with the filtering, means that efficiencies of around 90% or higher
with waveforms equating to steady DC are supplied albeit with a very small
amount of high frequncy ripple.
Ian.
Reply to Anonymous
<William P.N. Smith> wrote in message
news:k6blp0tr1uk2oe9h67qjfbjhq4scofrto4@4ax.com...
>>or
Thank you, William.
OK. That makes sense to me. Especially with Mike's follow on comment.
That leads to another question. Most, if not all Desktops have 4
voltages coming out of their power supplies, plus and minus 5v and plus
and minus 12v. For the most part the 12v are for drives, fans, etc. and
the 5v are for the IC's or whatever. Does everything inside a laptop,
drives and IC's run off of the one voltage, whatever it is, supplied by
the battery?
Thanks again.
Reply to Anonymous
"Electrik Fan Club" <ian.shorrocks@baeyourclothessystems.com> wrote in
message news:419b3045_1@baen1673807.greenlnk.net...
>> or
>> Thank you.
> from a
> works
> higher
> small
> Ian.
Thank you. I've run into RFI problems with that high frequency ripple
on a switching power supply for an Icom Amateur transceiver years ago.
A couple of torroids on the leads fixed it but it drove me nuts until I
figured out what was causing the problem.
Reply to Anonymous
You've actually seen an unregulated or linear laptop supply?
>problem...maybe.
Good point!
Note that the new Dell laptop bricks have what looks like a normal
barrel connector with two connections, but somehow the laptop can tell
the difference between the 70W and the 95W supply, and will refuse to
work with a non-Dell supply, so there's clearly some extra signalling
going on there...
Reply to Anonymous
"Barry Watzman" <WatzmanNOSPAM@neo.rr.com> wrote in message
news:419AAEC1.6030907@neo.rr.com...
> It's DC.
Figured that! :)
>> or half wave rectification. Is it filtered or smoothed in any way?
>> Thank you.
Reply to Anonymous
>the battery?
Laptops have power converters inside them that take the wall or
battery voltage (which can very a bit) and make the individual
voltages to run whatever parts are inside. 5V, 12V, 1-2V for the CPU
core, negative voltages for the RS-232 ports, whatever is needed.
Reply to Anonymous
Thanks again William. That makes sense.
news:foimp0lfi0bh0nr00nq4pr1jc3lagk7okl@4ax.com...
>>plus
>>and
>>by
>>the battery?
Reply to Anonymous
No, everything does not run off of one voltage.
The charger is a DC switching power supply for the laptop (in most cases
it is single voltage, but in a few cases part of the charging circuit is
in the charger and it supplies multiple voltages, and possibly even some
of the charging control logic).
Meanwhile, the laptop has within it yet another switching power supply
that supplies the multiple voltages needed internally by the laptop.
The charger's output is the input to this supply.
>>>or
> Thank you, William.
> the battery?
> Thanks again.
Reply to Anonymous
news:419B7416.1060805@neo.rr.com...
> cases it is single voltage, but in a few cases part of the charging
> circuit is in the charger and it supplies multiple voltages, and
> possibly even some of the charging control logic).
That makes perfect sense and I thank you.
>>>>wave or
>> Thank you, William.
>> comment.
>> plus and minus 12v. For the most part the 12v are for drives, fans,
>> etc. and the 5v are for the IC's or whatever. Does everything inside
>> a laptop, drives and IC's run off of the one voltage, whatever it is,
>> supplied by the battery?
>> Thanks again.
Reply to Anonymous
There are 1925 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Cant log into windows 7
By anort3, 2 days ago:
Sorry, we can't help you get around a password as we have no way of knowing if you are...
Best offers
Top experts
