Odd problems getting keyboard to work
I just picked up an Asus P67 and an i7-2600K, along with 8 GB DDR3-1600 RAM. I'm just swapping it out my ancient Pentium D 3.6 GHz so I can do HD video editing.
I am running into a problem with getting the board to recognize my keyboard that I have never ran into before.
The keyboard is an old Logitech Internet Navigator USB keyboard. I think it might be close to 10 years old, but has worked fine with every computer I've plugged it into, except this one.
This board doesn't recognize the keyboard if it is plugged into my USB hub, and only intermittently recognizes it if I plug it in using a USB extension cable.
Does this sound right to anyone? I bought it at Fry's yesterday and I still have the option of taking it back. I have not found any other errors with the board.
6 answers Last reply
More about problems keyboard work
  1. And it will not work in the designated purple Keyboard interface? Your keyboard should have come with that adapter - maybe in a drawer somewhere....
    Frys sells them if you don't have one.
    Save gas and, while you're there, pick up a cheap keyboard (that you can return) while you are there, and you will have the other piece of the puzzle.
  2. The keyboard will work fine from the P/S2 port, and intermittently when directly plugged into a USB port. However, I prefer to run fewer cables between my desk and my computer, so I usually use a USB hub for my keyboard, mouse, vdieo camera, microphone, micro-usb cable (phone, camera, etc).
    No devices work from the USB hub when connected to this motherboard, although it works fine on other computers.
  3. Many USB controllers claim backward compatibility from 2.0 to 1.1, when in fact they are not. If your keyboard or hub is USB 1.1, there is the source of the dysfunction. I have had a couple of hubs that would not work with my upgraded motherboards and now sit useless in the closet.
    Note that the blue rear ports are not backward compatible on the P8P67.
  4. Okay, so before you posted that I was on the Asus website and saw that if I upgrade from BIOS 1302 to 1502, one of the fixes has something to do with expanded USB capability, so I thought that might apply to me.
    Well, after installing the BIOS update, when Windows 7 boots up it automatically installs some kind of update for the CPU. I know this because it states 'new hardware driver installed Intel i7-200K', or something (it was only up for a moment after the login screen), and then Windows freezes, never to work or boot up again, although I can revert it to a previous successful boot, but then it just installs the 'new hardware' again. I really think there is something wrong with this board.
    The USB hub is a 2.0 hub and the keyboard is USB 1.1.
  5. It well could be the board, but it's starting to sound at least partially like a corrupted BIOS, I suggest you clear CMOS, then try again. If that doesn't work, then it would probably have to be a bad MB; Asus has had quite a few USB errors for the P67.
  6. You're better off buying a newer keyboard.
    I don't think Logitech has drivers for yours.
Asus Keyboards Motherboards Product
