My system consist:
Gigabyte P67A-UD4-B3 f3 bios
Intel Core i5-2500K 3.30GHz
GKill F3-10666CL7D-8GBXH
ATI Radeon HD6870
WD-640G Black edition - 2 hard drives
Corsair 600T case
My first issue was that it would keep going into a loop when I power on the unit where it would get to the logo and then it would repeat each time. To resolve that I change a setting in BIOS for memory set to XMS-Profile1 and that solve that but I also had F2 BIOS and updated the BIOS to F3.
Now I can't resolve about the shut down problem.
I tried several things as to what was suggest on the forum and it didn't help and now at the monument I remove all the front panel cables from mother board and then jumper the power on connector and waited to it finish booting up to Window 7 and then shut down the unit and still well not power off. The only way to do it was flip the power switch on power supply to the OFF position.
In the past I really had no problems building system and this is my first time using a Gigabyte motherboard.
I would like some other suggestions before I decide to return board for another brand.
ATI Radeon HD6870
Corsair 600T case
