Hey,
I just downloaded the driver version 10.6 from the AMD site (selecting the applicable card and OS, obviously) and after doing a custom install, instead of a message of completion with a green check mark, there's a message saying warnings have occurred with a yellow question mark. When I open the log, no warnings or errors are listed. Also, what I noticed is that there is no more Catalyst Control Centre on my PC, but there is a Catalyst Install Manager. I tried uninstalling the card using both the AMD uninstaller and the device manager and then reinstalling. Nothing seems to be working.
How do I get CCC to work and can someone tell me what the Install Manager is for?
Thanks for your time,
Spike
P.S. I have Windows 7 HP 64-bit if it means anything.
Spike
