Date of purchase: Now
Parts not needed: keyboard, mouse, and i will be using my 50" plasma 1080P TV for my monitor
Uses: HTPC Streaming TV, Recording TV, and playing DVD movies
DVD/CD drive
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Item #: N82E16827135204
$23.99
CASE
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146061
NZXT GAMMA Classic Series GAMA-001BK Black Steel ATX Mid Tower Computer Case
Item #: N82E16811146061
$49.99
Storage drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822136284
$89.99
PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371034
Antec EarthWatts Green EA-430D Green 430W Continuous power ATX12V v2.3 / EPS 12V 80 PLUS BRONZE Certified Active PFC Power ...
Item #: N82E16817371034
$49.99
Memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231253
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Dual Channel Kit Desktop Memory Model F3-10600CL9D-4GBNT
Item #: N82E16820231253
$81.99
Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121396
Intel BOXDH55HC LGA 1156 Intel H55 HDMI ATX Intel Motherboard
Item #: N82E16813121396
$99.99
CPU
Intel Core i3-540 Clarkdale 3.06GHz LGA 1156 73W Dual-Core Desktop Processor BX80616I3540
Item #: N82E16819115221
$124.99
OS
Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders - OEM
$139.99
Hard drive for OS:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820139133
Kingston SSDNow V Series SNV425-S2BD/64GB 2.5" Desktop Bundle 64GB SATA II Internal Solid State Drive (SSD)
Item #: N82E16820139133
$159.99
TV tuner:
Ceton
http://www.cetoncorp.com/products.php
On the website it says that you need a HDCP compliant on-board graphics or graphics card, Will my MOBO work or will i have to buy a separate video card?
Will the CPU be enough? or should i go with a quad core?
Any comment or suggestions would be appreciated.
DVD/CD drive
$23.99
CASE
$49.99
Storage drive:
$89.99
PSU:
$49.99
Memory:
$81.99
Motherboard:
$99.99
CPU
$124.99
OS
$139.99
Hard drive for OS:
$159.99
TV tuner:
Ceton
