Hi all,
Just got myself an antec 900 (i like it) and some arctic silver 5 (which imo is better than ceramique) Anyway, i basically popped the components i have into my antec 900 and made a small line across the cpu, around about a grain of rice and a little stripe more (very thin bit more tho) and then smeared it over the entire cpu top. I then popped the cpu cooler on and put the pc's side back together, now i don't know when or how but something must have gotten inside as when i powered it on it wouldn't come on, so i disconnected the power cable, re inserted and powered on, which it did.
It was at that time that i noticed a strange smell, so i bent down a bit and looked in the glass part of the case and noticed a new light? On sticking my face against the glass i noticed that this new light was infact a small flame! lol. So i made a worried face and ragged the cable out the back of the machine and unscrewed the back of the case like my life depended on it, opened it and blew out the flame which was around about a cm in height.
It had left a mark on the motherboard by the upper pcie slot, a small black chunk fell off while i was cleaning the black charred stuff off the mobo and black stains off something that resembled a transistor. I got it as clean as i could and got the case back on (no screws this time lol)
Powered it back up and waited (thinking that my baby had died)... the windows sign came on and the computer booted fine, no flames, no drama, nothing. (great)
Since then, i have had some seriously low temps (for me anyway) cpu temps have been down to 28 degrees C, my gpu temp (fan on 100%, is this ok to do by the way?) is idling on 44 degrees C.
The cpu temp over the last two days has risen to 39 -40 on idle, now i'm thinking that this might be after curing time, but it occured to me that it could be a problem post fire lol. Does anyone have any ideas on this? (besides try not to set your pc on fire)
Did i get the spreadiing of the paste wrong? Or could it be the burn on the mobo?
Cheers.
Specs:
Win7 64bit
AMD Phenom 2 x4 940 3.0ghz overclocked to 3.4 on stock voltage of 1.34v
4 gig ddr2 ram Corsair
2 500 gig hard drives
8800gs 384 meg using tweak forces driver (newest at time of post)
MSI 790GX motherboard
580watt g7 power supply
Cheers.
Specs:
Win7 64bit
