Ati radeon 3650 cs 1 6 fps problems
i have big problem with my fps in cs 1.6 and css my video card is bought yesterday and its ati radeon hd 3650 my fps with my oold nvidia 5200 was 70 - 99 but now with ati its only 30-70 wtf plz help
11 answers Last reply
More about radeon 3650 problems
  1. Re-seat the card and check with GPU-Z:
    http://www.techpowerup.com/gpuz/
    make sure GPU interface is at x16 and not below... :)
  2. how you think re-seat?
  3. hello plz help me
  4. re-seat = unplug the card and plug it again to the pcie slot... :)
  5. ok but where i should see that gpu interface?
  6. i think if you plug it properly it will automatically work if not the card will not work ... if you are encountering a low fps on your 3650 comparing with your 5200 i highly suggest update your driver ..... 3650 is my first card until now and i have a game end war running at 8-13 fps mid setting 15inch monitor before but when i update it the fps now is on the 18-21 still on mid setting ..... 3650 cant produce a lot fps even if you are in the part of no moving things lets say for example you are in the black area on counter strike source in free look mode the only max fps can give you is 60 unless if you have a nice processor there will be a possibility to increase
  7. can you give me some good working driver download sites plz )
  8. try the official web of ati they have a updated driver there .... can u give me the info of your os so i can only give you the link
  9. windows xp profesional 32 bit sp 3
  10. http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
    driver for gpu download the option 1 45.6mb
    http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonxip-xp
    download the hydra vision its on the 3 download bottom
    http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonxavivo-xp
    the last is download this avivo
    you need to install all this driver because some of the game will not affect if you just download the driver for the gpu i posted on the top 1st ..... game like Dirt2
    if still the same well all i can say is replace your 3650 into 4770 or 5670 ^_^ same as i did now ^_^
  11. thx for help now i will try
Radeon ATI FPS Graphics
