Need some help/advice for buying a system.
Hello. Now I know the opinion here on the forums is that it is better to build your own PC instead of buying a completed one from a vendor. I understand this, and agree as well. However, as of right now I am unable to. I won't go into specifics, but I can't. So, now the only option for me is to pick out a prebuilt system to buy.
I am using this to play games such as Starcraft 2, school work, and any other misc. task.
So far, here is the best prebuilt system I have found so far:
iBUYPOWER Gamer Power 549D3 Athlon II X4 635(2.9GHz) 4GB DDR3 500GB ATI Radeon HD 5770 Windows 7 Home Premium 64-bit
If you guys have a better system recommendations for a prebuilt system, I am open to opinions.
Budget: $700
Thanks for reading, and thanks for answering. :)
3 answers Last reply
More about need help advice buying system
  1. What sort of budget are you looking at?
  2. I've always been a fan of CyberPower (http://www.cyberpowerpc.com/) for those who don't want to build their own system. It allows you to customize your PC to fit your budget.
    iBUYPOWER has a similar offering (http://www.ibuypower.com/) where you can customize your PC to your hearts content.
    Just do some research on parts first. This site has some great monthly graphics card reviews, and some CPU reviews
  3. I'm looking at around a $700 dollar Budget. Sorry, I should have put that up there in the opening post. Forgot to.
Prebuilt Systems Build Your Own Systems Product
