I have an Iomega external HD which connects to the power supply via a 5 pin plug. One of the pins was completely bent and at the bottom of the jack, and when I tried to pull it straight, it broke (no surprise). Everything still works fine though. The pin that broke was separated from the other 4, so I guess it was a grounding pin? If that's the case, I was wondering how dangerous it is to operate the unit with a broken grounding pin (i.e. obviously it's there for a reason)? Thank you!
