Should case fans work if plugged directly to PSU?
Last response: in Systems
Related ressources:
- ForumCase fans connected directly to the psu ?
- ForumRouting Case Fans Directly to PSU Not Working
- ForumCase Fans to PSU or to motherboard?
- ForumComputer won't boot with CPU power cable plugged in, fans spin for a couple seco
- ForumHaving trouble plugging in case fans .
- ForumMy case fans plugged into motherboard don't turn on and no video
- Forum3 case fans - plug into motherboard or power supply?
- ForumTwo case fans ; which one should have system control?
- ForumPSU Issue? Case Fans and PSU Fans not working. CPU Fan Fine
- ForumWhere do I plug in case fans and USBs?
- ForumPlugging Case Fans to Z77E-ITX MB
- ForumCase fans into molex connectors from PSU ?
- ForumCase Fans not working, Corsair 500R
- ForumAntec 300 HELP - where do I plug the case fans ??
- ForumHow to connect case fans mobo pins or PSU power?
- ForumP7P55D-E EVO, PSU or Motherboard for case fans
- ForumWill the P67 Sabertooth boot if you don't have a CPU_ Fan plugged in?
- Forum120mm Case fans , Voltage question.
- ForumPCI compatibility question
- ForumHow can i get my information bar to work
- More resources
