This is my first post on TH for my first ever build.
APPROXIMATE PURCHASE DATE: Within the next month or so
BUDGET RANGE: $2000 before rebates; preferably including tax and S&H
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: CAD drafting (ACAD specifically) > gaming > internet/multimedia
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers
PREFERRED WEBSITE(S) FOR PARTS: newegg.ca, tigerdirect.ca
COUNTRY OF ORIGIN: Canada
PARTS PREFERENCES: I'm looking at Intel over AMD (but would gladly accept opinions to the contrary), otherwise, not too particular re: brands, but I demand quality of product/service. I would prefer Mid-tower and if I can get a pretty decent system without spending the full 2 G's that would be great!
OVERCLOCKING: No / Maybe later
SLI OR CROSSFIRE: No / Maybe later
MONITOR RESOLUTION: 1600x1200 minimum
ADDITIONAL COMMENTS: Some buzz-words: reliable, quiet, multi-tasking capable, easy installation
THIS IS MY FIRST EVER BUILD. I will have access to an experienced builder for troubleshooting, but I really would like to do it on my own. Please try to avoid products that are known to be finicky or more appropriate for vets.
I've taken a stab at selecting some components based on speed > positive user review > price.
CHASSIS: Not a super-critical part for me. I want something fairly well built and fairly easy to get along with.
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
The CPU/MoBo/RAM situation is nearly a complete mystery to me. I think I've found compatible products, but I don't know if they're more potent than I'll need, or whether they're even good choices. This is where I could use the most assistance!
CPU: Looking at Intel, but not sure if I need it. I want something that will last me and be at least a little useful in 3-5 years.
Intel Core i7-930 Bloomfield 2.8GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Desktop Processor BX80601930
MoBo: I've read good things about Gigabyte & Asus. Same req'ts as the CPU. Fit a Mid-tower case.
GIGABYTE GA-P55-USB3 LGA 1156 Intel P55 USB 3.0 ATX Intel Motherboard
Memory: Don't even get me started! Help!
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C8D
GPU: I like nVidia, I prefer EVGA, I don't want to spend an arm and a leg. Open to commentary, though. I'd like to be able to double up sometime down the road; I think the MoBo, PSU and GPU are all SLI-ready (right?!).
EVGA 01G-P3-1465-AR GeForce GTX 465 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
PSU: At a loss here; everything seems to be the same. Looking for the best quality/value. Heard good things about Corsair.
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
HARD DRIVE - I want to go the SSD boot, regular HDD storage rout. Not PRECISELY sure how to go about it, but I'm sure I'll be able to figure it out ;P
SSD Boot: Not a clue about this type of product. New to me, but I've heard great things. Feel free to comment.
OCZ Vertex 2 OCZSSD2-2VTXE60G 2.5" 60GB SATA II MLC Internal Solid State Drive (SSD)
HDD Storage: Just looking for reliable, fast and quiet. Primarily for media storage and application install.
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Optical Drive: Again, not a biggie. I want a reliable, quiet drive that won't cry when I rip DVDs.
ASUS Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Burner - Bulk - OEM
OS: I think I'm finally ready to let go of my beloved/hated WinXP. I could use some guidance with the version selection. I believe all the components I selected will work with 64 bit; not even sure if that's an issue.
Microsoft Windows 7 Ultimate 64-bit 1-Pack for System Builders - OEM
As I've got it added up on newegg.ca I've got a total of
$1627.41 ($1861.43 after taxes and S&H). I've laid out my requirements, now I leave it up to the masters to set me straight!
Anywhere you feel I can get away with a lesser product (less speed/size, not quality), let me know. Also, I did not touch upon the CPU cooler or fans. I'm hoping I don't need to upgrade the stock products as I'm not OC'ing and I won't be doing any extensive gaming (I'll be cracking out on SC2 and D3 when it comes out, of course
); but please set me straight if need be.
Thanks all!
