Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Sony PCG-F290 w W2000 powering into hibernate problems
Forum Laptops & Notebooks : General Laptops & Notebooks - Sony PCG-F290 w W2000 powering into hibernate problems
Archived from groups: comp.sys.laptops (More info?)
Native OS was W98. Upgraded to w2K Pro.... since then have had
issues with laptop dropping into hibernate with no warning. If I boot
up in setup or command prompt left over from W98, it will not jump
into hibernate. My power scheme in power settings is everything
"never" and I have "enable hibernate support NOT checked and
Advance power management checked. I have tried different
combinations of setting with so apparent luck...and I have tried
different AC transformers as I have another SOny laptop... ANY
IDEAS thx DZ
Sponsored Links
> IDEAS thx DZ
If you have installed the Sony Power Panel, or other Sony power
management app, try it for management. I've noticed some odd occurences
of non-compliance using the Windows power management when the Sony app
is also installed.
Q
Reply to Anonymous
There are 666 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
