CM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119216&cm_re=cm_690ii-_-11-119-216-_-Product
Lain Li:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112239&Tpk=pc-k62
I'm looking to spend no more than $100 on my case. If you select other, name the case you'd suggest and why.
Lain Li:
