Xtremegear 700 watt power supply
Hello,
is this a good power supply for the P8P67LE motherboard
6 answers Last reply
More about xtremegear watt power supply
  1. I doubt it's any good, but we'll need the exact model as well as the system's specs, e.g. GPU, CPU, etc.
  2. it has i7-2600 3.4GHz,
    (4) Kingston Technology HyperX 4 GB Modules 8 Dual Channel 1600MHz 240-Pin DDR3 SDRAM,
    LITE-ON 4x Blu-ray Disc SATA Internal Optical Drive iHOS104,
    Seagate Barracuda 7200.12 SATA 6Gb/s 1 TB Internal Hard Drive with 32MB Cache,
    Motherboard: ASUS P8P67LE B3 Revision
    (6) USB 2.0 (back)
    (2) USB 3.0 (back)
    PS/2 Mouse (back)
    PS/2 Keyboard (back)
    Center/subwoofer port (back)
    Rear speaker port (back)
    side speaker port (back)
    auto line in (back)
    microphone port (back)
    headset port (back)
    in a Burton GS-6500 Tower:
    (4) 120mm led fans
    (2) 80mm led fans
    (4) USB 2.0 in front
    Multi card reader (front)
    Video card not purchased yet.
    OS will be Windows 7 64 bit
  3. what power supply do u recomend
  4. ^+1
    What's your budget? And will you have two graphics cards at any point in the future? Assuming you will, check out the TX750 V2.
  5. delluser1 said:
    Specifications indicate that this is an overated 500 or 550 watt PSU.
Asus Power Supplies Motherboards
