Yes No
Ads
Tom's Hardware > Forum > Systems > Homebuilt > Fresh Built, and constant BSOD
Forum Systems : Homebuilt Fresh Built, and constant BSOD
I just built this computer today. I was having a hard time getting the system to boot today, i took off the mounting screws, then test them back on one by one, then the components one by one. After many tries, it worked. And now i keep getting a 1a BSOD every 2 minutes. I am using the memtest86 to test the system right, it's not looking good.
Reply to blazed1k
It would help to know the specs of your components, particularly the RAM. Half the time, this kind of problem is caused by the RAM having a higher-than-usual voltage requirement, but the user leaves the voltage on "auto." If it's anything other than 1.8V for DDR2 or 1.5V for DDR3, chances are you're going to have to set the correct voltage manually in the BIOS, and then this will go away.
Reply to capt_taco
I am very sorry for not mentioning my specs. I have checked the voltage, and it is running at 1.5V for my DDR3 RAM.
Specs:
- XFX HD-577X-ZNFC Radeon HD 5770
- G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM
- GIGABYTE GA-770TA-UD3 AM3 AMD 770 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
- Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
- COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case
- AMD Athlon II X3 440 Rana 3.0GHz Socket AM3 95W Triple-Core Desktop Processor
- LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
- OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7
One thing i don't get the most is what is the correct to mount the motherboard to the case? Does it matter how I mount it to the case? A friend have told me that the manual would tell you exactly which spots you should put the screws in. And another thing, the case or the motherboard didn't came with any standard screws, just the bronze ones that you use to mount the underneath of the motherboard.
Today I have tested with my older Power Supply, and Graphic Card. They both have the same BSOD(0x0000001a). I have attempted change into an older IDE hard drive and install Windows 7 64-Bit. I have received the following BSOD during the Windows installation:
0x00000050(0xFFFFF8802443DC38, 0x0000000000000000, 0xFFFFF8000CFBD7CA, 0x0000000000000002)
This is my very time building a computer, and it's been a very unpleasant experience. If i have made any mistakes, please correct me.
EDIT: I believe I probably should return the Motherboard and RAM, since I don't have an extra pair of DDR3 RAM to test. I have purchased everything from NewEgg. Although I shop in there frequently, I have never returned anything to Newegg before. How are you experience returning items to Newegg?
Message edited by blazed1k on 07-31-2010 at 06:57:00 AM
Reply to blazed1k
Quote :
It's often hard the first time, but gets easier.
If you look at the sticky at the top of the forum, you will find two things that will help you quite a bit.
The first one is "Step-by-Step Guide to Building a PC" by Tecmo34
http://www.tomshardware.com/forum/ [...] e-building
The next one is "PERFORM THESE STEPS before posting about boot/no video problems! " by shortstuff_mt
http://www.tomshardware.com/forum/ [...] o-problems
Also, have a look at this link about BSODs:
http://www.maximumpc.com/article/f [...] e?page=0,0
------------------------------ Waiting for an answer? I lost the flag to the post. Send a PM
My Guide to choosing parts
Troubleshooting Guide
PSU Guide
Reply to Proximon
I don't know what kind of G.SKILL memory you have exactly, but you should know two things:
-Gigabyte AM3 and G.SKILL don't get along on a regular basis.
-If you bought G.SKILL memory that doesn't specifically say it plays nice with AM3, the settings on the box are lies and you'll have to research the *AM3-APPROPRIATE* settings if you're interested in anything other than constant BSODs.
I know this because trying to untangle this G.SKILL/Gigabyte AM3 mess has been my life for the past four days. Rest assured I won't be dumb enough to combine the two again...
You can also try updating your motherboard's BIOS.
Reply to deepruntramp
Yup, seeing a lot of error codes like "0x0000000000____" is another good indicator of RAM issues (voltage, bad stick of RAM, etc.)
Can you give us the specific model number of G.Skill RAM? They make several kinds 0f 2x2GB DDR3 kits. Some of them take 1.5V, some are 1.6V and some are 1.65V so it's important to know which of these you've got.
http://www.newegg.com/Product/Prod [...] M+&x=0&y=0
Reply to capt_taco
Wow you guys are right!! I just bought a new pair of RAMs today. And headache solved! Thanks guys!
Reply to blazed1k
There are 1851 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Need Feedback on $1800 Gaming Build
By Hopz, 1 hour ago:
Could save some money on your PSU and CPU cooler. Unless you want to OC above 4.5 Ghz the...
Best offers
Top experts
