Archived from groups: microsoft.public.windowsxp.configuration_manage (
More info?)
Thanks Jim
We tried the different user name but it still locked the account.
Here was our simple fix: Map the drive, create a short cut of the mapped
drive to the desk top, then disconnect the mapped drive. Any subsequent
time that the user logs in all they need to do is click the short cut and
they get a login screen.
W did attempt the login script which worked fine. We preferred the Gui login
box to the script command prompt box that many of our staff would not be
familiar with.
Dan
"James Fabulous" wrote:
> Dan,
> Have you considered using the "Map network drive" feature and specifying
> a different username and password - Although this is something I'm currently
> experiencing some odd behavior with (reconnection issues) the behavior
> should work to solve your issues. Another solution is to use a local
> loginscript - a simple batch file in the startup folder of the local user
> mapping the drive with domain credentials.
> Syntax of: net use [drive letter]: \\[member-servername]\[sharename]
> password /user:[domainname]\[domain-username] /persistent:YES
> Word of warning here that the password is kept in plain text - <MS guilt
> trip> C'mon folks how long has the 'net use' command been around and we
> still have to worry about plain text passwords? </MS guilt trip> so it is
> inherently insecure - however I've found a couple of neat VBS scripts that
> can prompt for username and/ or password that you can simply embed in the
> batch files - users enter the password once and the drives are mapped.
> (Great for users offsite with expired passwords).
> VBS - search for userin.vbs and passin.vbs
> Hope this helps,
> JF
> "Dan" <Dan@discussions.microsoft.com> wrote in message
> news:85FD60CF-CE69-4B6D-A2EB-8C604D3270AC@microsoft.com...
> > We have several Windows XP workstations in a workgroup configuration.
> They
> > have a persistent connection to a mapped drive on a domain-member server.
> > The users are trying to log in to a local account on that server.
> > Because the workstation password is different than the mapped-drive
> > password, that local account keeps getting locked out and the users have
> to
> > wait 30 minutes, after which time they can access it with no problem.
> > Barring that they can log in if we unlock the account. What we suspect is
> > happening is the Windows is attempting to connect to the drive with the
> local
> > account used to log onto the XP workstation and retrying a few times after
> > the password fails.
> > The following errors appear in the event log.
> > Event Type: Failure Audit
> > Event Source: Security
> > Event Category: Account Logon
> > Event ID: 681
> > Date: 4/22/2005
> > Time: 11:43:55 AM
> > User: NT AUTHORITY\SYSTEM
> > Computer: SERVER01
> > Description:
> > The logon to account: lsmith
> > by: MICROSOFT_AUTHENTICATION_PACKAGE_V1_0
> > from workstation: WRK01
> > failed. The error code was: 3221225578
> > Event Category: Logon/Logoff
> > Event ID: 529
> > Date: 4/22/2005
> > Time: 11:43:55 AM
> > Computer: SERVER01
> > Description:
> > Logon Failure:
> > Reason: Unknown user name or bad
> password
> > User Name: lsmith
> > Domain: WRK01
> > Logon Type: 3
> > Logon Process: NtLmSsp
> > Authentication Package: NTLM
> > Workstation Name: WRK01
> > We know the best solution would be to make them all members of a domain
> and
> > use domain accounts. Suffice it to say that is not an option. Increasing
> > the number of failed attempts before the account locks is also not an
> option.
> > What we think would be a good workaround is to find a registry fix that
> > would limit the number of login retries to 1, so the user would get
> prompted
> > with a password rather than the system retrying multiple times and locking
> > the account. Does anyone know how to do this?
> > Any other ideas would also be appreciated.
> > Thanks Dan
