Hi,
I'm doing a system build for a friend. I've done several before, but I always like to get feedback from the experts before I spend a bunch of money. The goal with this system is to build a good gaming system for around $1000 (not counting a monitor). Here's what I was thinking:
GIGABYTE GA-870A-UD3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128443
Phenom II X4 965 Black Edition Deneb 3.4GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
XFX HD-585X-ZAFC Radeon HD 5850 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150477
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
BFG Tech GS-550 550W ATX12V Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817702010
COOLER MASTER ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
ASUS Black 24X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
Total comes to $1,005.91, plus some for shipping. Does that look alright? Thoughts?
