Problem with motherboard? Or Cpu???
Hallo,
My computer is not starting. My motherboard is crosshair 4 formula and processor is amd 1090t. Last night it was running well. But this morning when i hit the power switch, motherboards probit light of cpu dont turns off. And in somewere i read if i remove ram then i will hear continues beeping what will prove my motherboard is working but i hear none. So i cant find out what is the problem? Is my motherboard gone or processor? Please help me. I am new here. (my english is not so good sorry for any mistake)
6 answers Last reply
More about problem motherboard
  1. The first thing that I would check is the PSU. If you are sure that the PSU is working, then make sure that it is firmly connected to your motherboard.
  2. i check my psu in my friends pc its ok. And its a xfx core edition 750W. I bought it a week ago. i feel like a dead man when my pc is dead....:(
  3. Try booting with just one stick of ram in the #1 slot (closest to the cpu) If you can't boot, try your other ram stick in the first slot, if you still can't boot it is more than likely a motherboard problem. Assuming that it isn't booting because of an overclock issue.
    The "feeling like a dead man" part, is out of my league, maybe some booze will help.
    peace
  4. it could be a overclock problem. Motherboard's O.C. button was switched on. Am i still under warrenty if it is am overclock issue?
  5. Reset back to default and see if it boots. I doubt that you would still be in warranty if you overclocked. Call them up
    I press the CLR_CMOS switch in the back panel of the motherboard but nothing different happen.
Asus Processors Motherboards CPUs
