Solved
Will a 3-pin Power Connector work on a 4-pin fan header?
  • Power Supplies
  • Fan
  • Power
  • Components
Last response: in Components
October 2, 2010 2:50:42 PM
I have a question will a 3-pin Power Connector work on a 4-pin fan header or vice versa?
More about : pin power connector work pin fan header
Best solution
a c 243 ) Power supply
October 2, 2010 2:52:54 PM
Yes, a 4 pin on a 3 pin header won't have PWM control though
a b ) Power supply
October 2, 2010 5:11:25 PM
No adapter needed, just plug them with the PWM-pin unfilled.
m
l
October 4, 2010 2:51:46 PM
Quote:
they do make adapters for just such things..
Yeah they do but they don't make them for a 4 pin header only 4-pin connector for the PSU.
m
l
October 4, 2010 5:59:37 PM
What like?
@Timop but what about fourth pin on the header what's that for?
m
l
a b ) Power supply
October 4, 2010 10:48:13 PM
ITsonic said:
What like?
The fourth pin is for PWM, a form of fan speed control.
3-pin fans can still change speeds, the Mobo simply reduces the volts supplied.
m
l
October 5, 2010 1:20:16 AM
So the Mobo will make the fan run at a slower speed or something by reduceing the volts?
m
l
October 6, 2010 2:13:23 PM
Best answer selected by ITsonic.
m
l
June 17, 2013 4:09:11 AM
but my cpu fan maxed out with 3-pin connector on 4-pin header
m
l
September 13, 2014 5:04:54 PM
Oops i didn't mean to choose this as the solution. Anyway i'm having the same problem as you. Is the 3-pin supposed to be connected to the left side or the right side :S http://prntscr.com/4ml74n
m
l
