Need advice on build
Is this system any good for cheap gaming build but mostly for starcraft 2. Trying to spend at least as possible. I already have a case and HDD. Anything that I could change for possibility for upgrades?
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model F3-10666CL9D-4GBNQ
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231190
AMD Athlon II X3 440 Rana 3.0GHz Socket AM3 95W Triple-Core Desktop Processor ADX440WFGIBOX
MSI 870-G45 AM3 AMD 870 ATX AMD Motherboard
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.437019
EVGA 512-P3-N871-AR GeForce 9800 GTX+ 512MB 256-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Thermaltake TR2 W0388RU 600W ATX 12V v2.2 Power Supply
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.431550
Thanks!
4 answers Last reply
More about need advice build
  1. Ouch the GTS 250 though a refresh of the 9800GTX+ is both more cooler running and eeks out a tad more frames Also hell no to TT TR2 line of PSUs!
    http://www.hardwaresecrets.com/article/Thermaltake-TR2-RX-750-W-Power-Supply-Review/902/9
    Quote:
    Conclusions
    Thermaltake TR2 RX 750 W is, according to our methodology, a flawed product that must be avoided at all costs. It can’t deliver its labeled wattage at high temperatures, but this is not the worst of it: ripple and noise level are way above the maximum allowed when you pull 80% or more from the unit’s labeled capacity (i.e. 600 W and above), overloading your components (especially electrolytic capacitors from the motherboard and video cards), which can cause your PC to present an erratic behavior (crashes and random resets) and, under extreme conditions, damage components.
  2. Counter proposal: $347AR
  3. Thanks guys!
  4. You are welcomed ^^
New Build Systems Product
