Solved
Need some help with the external parts of this build.
Posted a week or so ago asking about what motherboard I should get for my new build. Got some good advice, so I'm back with a few more questions.
Here is what my build will be:
CPU - Intel Core i7-860 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115214
Motherboard - ASUS P7P55D-E Pro LGA 1156 Intel P55 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621
Video Card - GIGABYTE GV-N460OC-1GI GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814125333
Memory - G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
SSD - Intel X25-M Mainstream SSDSA2MH080G2R5 2.5" 80GB SATA II - http://www.newegg.com/Product/Product.aspx?Item=N82E16820167023
HDD - SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache - http://www.newegg.com/Product
/Product.aspx?Item=N82E16822152185
Case - SILVERSTONE RAVEN RV02-BW - http://www.newegg.com/Product/Product.aspx?Item=N82E16811163154&Tpk=RV02
PSU - SeaSonic X650 Gold 650W - http://www.newegg.com/Product/Product.aspx?Item=N82E16817151088&cm_re=Seasonic_650-_-17-151-088-_-Product
Now, I need to decide on some of the external parts.
Speakers - I wanna go with a 2.1 set. Would like the cleanest sound I can get, willing to spend about 70 bucks on speakers.
Mouse/Keyboard - I'd like to go wireless for the mouse, but I could go wired I guess. Mainly I'm just trying to avoid wire clutter. I'll be gaming, so I dunno how well wireless goes with that, I've never had a wireless set. Any advice?
Monitor - I was looking at some 27inch monitors, but I hear going this big can lead to frame rate drops in games. I 1920x1080. So I guess my main concerns would be it being to big and if it gives any problems for gaming with a screen this big. I could easily go 23-25 inches as well, just wanna know what the best quality monitors out there are for gaming. I'd be willing to spend up to 300 on monitors, maybe 350.
If I need to give anymore info to help you guys help me, then lemme know. Thanks again!!
5 answers Last reply Best Answer
More about need external parts build
  1. Best answer
    Speakers -
    Logitech Speaker System Z523 with Subwoofer
    http://www.amazon.com/gp/product/B002FU5QMK?ie=UTF8&tag=logicbuy-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B002FU5QMK
    KB and Mice
    Wireless Desktop MK700 from Logitech®
    http://accessories.us.dell.com/sna/productdetail.aspx?sku=A3869108&cs=19&c=us&l=en&dgc=CJ&cid=24471&lid=566643&acd=10550055-1727683-
    Monitor -
    ASUS VH236H Black 23" 2ms(GTG) HDMI Widescreen Full HD 1080P
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059
    If you want a LED backlit, and a good looking monitor
    SAMSUNG XL2370-1 Charcoal Gray 23" 2ms Full HD HDMI LED Backlight
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824001380
    Now as for the parts,
    If it is going to be a gaming PC, then IMO the i5 760 would suffice...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115067
    And any specific reason for that case ??
    You can save good money with this CASE + PSU and both are of high quality too...
    Lian-Li K62 + XFX 650W
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.440193
    RAM - Get a better timing one...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231278
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
    SSD - Check this one -
    Crucial RealSSD C300 CTFDDAC064MAG-1G1 2.5" 64GB SATA III - With the SATA III interface, it would offer very good speeds...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820148357
    Also with the money saved, you can add 1 more GTX 460 in SLI...
  2. Thanks, I'll end up getting those speakers and mouse/keyboard.
    I think I'd like to go a bit bigger on the monitor though. Any suggestions on 25inch or 27inch?
  3. Maybe this one ?
    ASUS VW266H Black 25.5" 2ms(GTG) HDMI Widescreen 1920 x 1200
    http://www.newegg.com/Product/Product.aspx?Item=N82E16824236047
  4. Best answer selected by perpetualrei.
  5. At 80 GB, the best bet is the Intel X25-M you selected. At smaller sizes, go for an OCZ Vertex 2. Unlike other SSDs (the C300 included), the controller used in the Vertex 2 does not lose speed as you decrease the size of the disk.
    To address your original question about the monitor, getting a larger-sized screen doesn't affect the fps. It's only increasing the resolution that does so. A 30" 1920x1080 monitor, a 24" 1920x1080 monitor, and a 17" 1920x1080 monitor will all have the same fps with the same graphics card. A 24" 1920x1080 monitor and a 24" 1680x1050 monitor with the same card will have different fps. That being said, a 460 should be adequate for most games at 1920x1080.
    If this is a gaming build, do you really need the i7-860? The hyperthreading offered by the i7 (compared to the i5-750) doesn't do anything for games.
New Build Systems Product
