Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > Dell Vostro 410 Power Supply upgrade. Help?
Forum CPU & Components : Power Supplies, Cases & Mods Dell Vostro 410 Power Supply upgrade. Help?
Hello, I've worked in the summer break just to earn some money from which I could upgrade my graphics card (Gigabyte's GTX460 1GB) for which I need to upgrade my PSU.
It comes down to this: I'm confused. I have found people on the internet that say that the power supply is propriety or something so I can't change it.
Other people said that it would be no problem to put a normal ATX PS in it because they stopped doing propriety Power supplies in the Pentium III days.
Now, what should I believe? I opened my case to find out that some weird metal things in my case hold the PS in place or something. Like 2 little 'hills' or something. The size up to those 'hills' (don't know what to call it) is 140 mm with a height of 85mm. Now, not looking at those hills it could be 150mm (which nearly all power supplies are!)
The mobo is a Foxconn DG33A01. With a 24pin connector.
If you know anything about this, please help me out. I'm worried now. When I bought this PC 2 years ago it said that it was good for later upgrades.
So, yeah. Please help! :/
Reply to LtStrike
Pretty much any standard ATX power supply will work.
Act quick and you can still catch the deal on this
http://www.newegg.com/Product/Prod [...] 6817139004
Reply to delluser1
to be honest, it might just work.
the vostro psu is rated at 350watts, but it is noted that the dell psu's are under-rated.
it's basically a known fact about them.
the gtx460 calls for a 450watt supply. so unless you have upgraded you cpu to a more power consuming cpu, i would give it a try.
now with that being said, Corsair makes awesome power supplies and ones to fit your vostro case.
------------------------------ A+, Net+, MCDST, DSCE (Dell)
Reply to malmental
Okay but what about the sizes? any power supply nowadays are like 150mm long, and I think there's only space for 140mm? There's loads of space after those 2 metal 'bumps' I mentioned. Should I simply get a saw and chop it off? Or what? xD
I don't know, I'm afraid of taking risks :P
Reply to LtStrike
The "bumps" won't be a problem. They are clips meant to hold the stock psu but will easily push out of the way for installation of an aftermarket unit.
Dell power supplies are not under-rated, that's a notion that came about due to them being rated properly, by max continuous output, not peak output like many generic psu's.
Reply to delluser1
i've tried many times to fry different dell psu's.
i mean totally abuse them to see exactly what they can handle.
as far as I'm concerned, they're under-rated and by your explanation,
" Dell power supplies are not under-rated, that's a notion that came about due to them being rated properly, by max continuous output, not peak output like many generic psu's. "
to some people they can construe that we're basically saying the same thing in different ways.
fellow dell guy.!
'bumps' will not be an issue as - delluser1 states.
Message quoted 1 times
Message edited by malmental on 10-03-2010 at 02:44:00 PM
Reply to malmental
Okay :)
Thank you so much, sir. You've made my day. ^^
Reply to LtStrike
fellow dell guy.!
Ty =)
Reply to LtStrike
There are 1853 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 9 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
